2000 Dodge Dakota Transmission shifting
100,000 MILES • V8 • 4WD • AUTOMATIC
JOEVAN
When my truck is cold it won't shift. It starts in second and won't shift into overdrive. If I turn the truck off and restart it, it will shift. It throws the check engine light and code comes up P1784 - pressure switch. How do I fix the problem?
Feb 14, 2010 at 3:17 AM
  • 110,246 POSTS
It sounds like a govenor problem. I would recommend a trans tech to service this problem.
Feb 19, 2010 at 1:39 AM
