2000 Dodge Dakota trans, slips
94,000 MILES • V8 • 2WD • AUTOMATIC
DAKOTABALLIN313
i just bought an r/t three weeks ago. now when i get on the gas in any gear the rpms go to about 5,500 and rev out. to change gear i have to let go of the gas pedal and then apply the gas again. does anyone know what the problem can be? i just changed the throttle body to see if any change nothin.
Jan 26, 2008 at 3:17 AM
BMRFIXIT
  • 19,053 POSTS
[quote:f653523447="dakotaballin313"]Transmission problem
2000 Dodge Dakota V8 Two Wheel Drive Automatic 94000 miles
i just bought an r/t three weeks ago. now when i get on the gas in any gear the rpms go to about 5,500 and rev out. to change gear i have to let go of the gas pedal and then apply the gas again. does anyone know what the problem can be? i just changed the throttle body to see if any change nothin.[/quote:f653523447]
did you check for codes
i think you should start with that
Jan 26, 2008 at 12:20 PM
DAKOTABALLIN313
yea i have no codes and engine light isnt on
Jan 26, 2008 at 2:38 PM
BMRFIXIT
  • 19,053 POSTS
[quote="BMRFIXIT"][quote:0b372e12d5="dakotaballin313"]Transmission problem
i just bought an r/t three weeks ago. now when i get on the gas in any gear the rpms go to about 5,500 and rev out. to change gear i have to let go of the gas pedal and then apply the gas again. does anyone know what the problem can be? i just changed the throttle body to see if any change nothin.[/quote:0b372e12d5]
did you check and scan the TCM also check tranny fluid use only CHRY approved ATF only
Jan 26, 2008 at 3:38 PM
DAKOTABALLIN313
tranny fuild was find dont know what kind because it came with it done
Jan 27, 2008 at 3:01 AM
