2000 Dodge Dakota Stops blowing cold after about 30 min of
147,000 MILES • V8 • 2WD • AUTOMATIC
RYAN1225
  • 9 POSTS
A/C blows cold for about 30 min of highway drive time, then starts to blow at about 73 degrees. Happens EVERY time I drive it. The compressor cluch does engage but never cycles on or off, is it supposed to? I have checked the compressor clutch relay and all seems to be fine with that. I have found that if I turn the A/C on and off periodically while driving (5 min on - 5 min off), it will continue to blow cold when I turn it back on. Have any ideas???
Aug 18, 2009 at 4:57 AM
DOCFIXIT
  • 18,828 POSTS
Most likely faulty clutch cycling switch mounted on accumulator(receiver dryer)
Aug 18, 2009 at 5:12 AM
