2000 Dodge Dakota SPUTTERS AND STALLS
SANWIL
Engine Performance problem
2000 Dodge Dakota 6 cyl Two Wheel Drive Automatic
sputters while driving and stopped, stalled twice at lights. changed spark plugs, no change. starts real easy
Jul 25, 2010 at 10:21 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 25, 2010 at 4:05 PM
