2000 Dodge Dakota Replace pick-up coil on Distributor
2000 DODGE DAKOTA
96,000 MILES • 6 CYL • 2WD • MANUAL
BOWMJRRY08
How to replace the pick-up coil on the distributor? Do I need to remove the Distributor from the Block or can I replace it without removing?
Jan 29, 2010 at 7:28 AM
  • 110,244 POSTS
Some can be done from the top without removal. Check to see. If it needs removed, you will need to remove the gear to get the shaft out.
Feb 4, 2010 at 2:18 AM
