2000 Dodge Dakota rear axle
PILF
Drive Train Axles Bearings problem
2000 Dodge Dakota 6 cyl Two Wheel Drive Automatic
need to find out what model and gear ratio is in this truck need to replace rear axle numbers i got off it dont match #9920145-23723687 off diff. cover #t84hs3760a off tube thanks cmf
Feb 22, 2010 at 12:49 PM
  • 110,248 POSTS
You will need to contact the dealer with that info. However, since the truck is 2wd, the gear ratio doesn't have to be the exact same as you have.
Feb 24, 2010 at 5:26 AM
