2000 dodge dakota problem...
MBRATBERG
alright here's the deal I own a 2000 dodge dakota 4.7 liter v8 with just under 50,000 miles. When I drive it the car will start out fine for a few miles and all of a sudden when I drive at about 45 mph or so it will pull back sharply. Then the engine rpm will go up to about 2.5 on the gauge and when I come to a stop and try to start up again the engine starts out very slowly and doesn't seem to want to shift. Also sometimes when I am done driving and start it back up again a few minutes later it has a lot of problems starting up, I have to step on the gas multiple times for it to turn over. Also sometimes it idles funny, the rpm gauge will jump from about .5 to about 1.5 without me stepping on the gas. I have 2 fault codes p0320 and p0700. I have recently changed out the battery and don't know if that is the problem. The codes seem to point to a circuitry failure but I am stumped as to what the problem actually is and what I should do.
Jul 19, 2006 at 12:51 PM
LUCKYJON
Hi, have you replaced or cleaned the 02 sensor on the throttle body? if not, i think you need to either clean it with a parts cleaner or, just have it replaced. my dodge dakota use to stall out of now where when i let go of the gas pedal, or, if idling, the rpm would go up and down, after i cleaned both the 02 sensor and the throttle body, i never have any of that problem anymore, just wanted to advise you of my thoughts.
Sep 7, 2017 at 10:27 AM
CARUNDELL
  • 602 POSTS
[quote:8206f2029b="mbratberg"]alright here's the deal I own a 2000 dodge dakota 4.7 liter v8 with just under 50,000 miles. When I drive it the car will start out fine for a few miles and all of a sudden when I drive at about 45 mph or so it will pull back sharply. Then the engine rpm will go up to about 2.5 on the gauge and when I come to a stop and try to start up again the engine starts out very slowly and doesn't seem to want to shift. Also sometimes when I am done driving and start it back up again a few minutes later it has a lot of problems starting up, I have to step on the gas multiple times for it to turn over. Also sometimes it idles funny, the rpm gauge will jump from about .5 to about 1.5 without me stepping on the gas. I have 2 fault codes p0320 and p0700. I have recently changed out the battery and don't know if that is the problem. The codes seem to point to a circuitry failure but I am stumped as to what the problem actually is and what I should do.[/quote:8206f2029b]
Hey mbratberg,
What are the code descriptions for p0320 and p0700 and I may be able to help you out further.
Regards,
Chris
MBRATBERG
I got the problem fixed, it ended up being the crankshaft sensor. Thanks for trying to help me though, I appreciate it
