2000 Dodge Dakota one dim headlight
PETERANDDONNA
  • 23 POSTS
Electrical problem
2000 Dodge Dakota 6 cyl Four Wheel Drive Automatic
the drives side headlight is dim i tried re grounding it like it was described in your electrical section,but the headlight stays on even then the switch is off can you help thanks
Sep 24, 2009 at 2:29 AM
  • 110,248 POSTS
Are the connections in the plug clean and making good contact?
Sep 26, 2009 at 4:59 PM
PETERANDDONNA
  • 23 POSTS
connection seems clean and is making good contact
Sep 26, 2009 at 11:25 PM
