2000 Dodge Dakota V8 Two Wheel Drive Automatic
My 2000 Dodge Dakota passenger headlight went out, Replaced it, new one is very dim ( appears to not be grounded). Test light shows bright lite to one of the three wires and a dim lite to another when on and in normal position, tested the same wires with bulb removed and the dim lite (wire) was no longer lit. Grounded that wire and the light worked Perfect (normal and brights) except the lights NOW would not shut off, tried grounding the other wires with the same results. Body grounds are good and battery grounds are good! Also all fuses are good! Any Ideas? Cant afford shop fees.
Thanks
Woodfile
SPONSORED LINKS
Tuesday, December 29th, 2009 AT 9:42 PM
