2000 Dodge Dakota oil pump
2000 DODGE DAKOTA
75,000 MILES • V8 • 2WD • AUTOMATIC
THEBEEF73
were and how do i change the oil pump on this truck
Nov 18, 2008 at 8:59 AM
  • 110,240 POSTS
Hi:
The oil pump is in the oil pan. To replace it you need to remove the oil pan.
Nov 18, 2008 at 3:06 PM
THTANOYINGUY
[quote:141c3e1e96="thebeef73"]Engine Mechanical problem
2000 Dodge Dakota V8 Two Wheel Drive Automatic 75000 miles
were and how do i change the oil pump on this truck[/quote:141c3e1e96]
remove the starter, trans dust shield, support engine and loosen engine mounts and unbolt pan..you ill have to finagal the pan off but you can do it...then unbolt pan and pump. clean pan and replace.
Mar 10, 2009 at 12:33 AM
