2000 Dodge Dakota Head gasket replacement.
2000 DODGE DAKOTA
16,000 MILES • 6 CYL • 2WD • AUTOMATIC
STRYPED
  • 37 POSTS
Is this hard to do on a 2000 v6 Dakota ? Do the head bolts have to be replaced?
Dec 18, 2008 at 6:55 AM
  • 110,244 POSTS
Hi:
It's no harder than other engines. It is, however, unusual to see a bad head gasket on a 3.9. Are you sure it's the head gasket?
Also, if you replace the gaskets, I strongly recommend replacing the head bolts and following the recommended torque sequence and steps.
Dec 19, 2008 at 5:45 AM
STRYPED
  • 37 POSTS
[quote:2c1ec9f4c7="Jacobandnickolas"]Hi:
Joe[/quote:2c1ec9f4c7]
It is overheating and blowing alot of white smoke. What else could it be?
Dec 19, 2008 at 5:47 AM
  • 110,244 POSTS
Hi:
It sounds like a headgasket or intake. Regardless, to get to the heads, you'll need to remove the intake. If you run into trouble, let me know. Also, make sure to have the heads checked for warpage.
Let me know how it goes and make sure to replace the thermostat.
Dec 19, 2008 at 7:50 AM
