2000 Dodge Dakota Dip Stick stuck in engine
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
LSHOEMAKER
Engine locked up, tried to pull out dip stick to check oil could not get released. Transferred to Dodge Dealership said a piece of the piston jammed in crankshaft. needed crankshaft and pistons replaced. Does this sound right? Normally if piston jams oil will burn, took off oil pan and checked. Oil not burned.
Jul 30, 2010 at 8:33 AM
  • 110,248 POSTS
When you took the pan off, were you able to see any broken parts wedged in the crankshaft? Also, as far as the oil, it wouldn't do anything to it.
Aug 15, 2010 at 4:12 PM
