Engine locked up, tried to pull out dip stick to check oil could not get released. Transferred to Dodge Dealership said a piece of the piston jammed in crankshaft. needed crankshaft and pistons replaced. Does this sound right? Normally if piston jams oil will burn, took off oil pan and checked. Oil not burned.
Jul 30, 2010 at 3:33 PM
