2000 Dodge Dakota clutch master cylinder
2000 DODGE DAKOTA
NELSONLAMBRIGHT
Transmission problem
2000 Dodge Dakota 6 cyl Four Wheel Drive Manual 100k miles
I replaced the clutch master cylinder now I need to bleed the air out of the system. How do you bleed the system there is no bleeding screw or valve at all; that I could find.
Jan 28, 2009 at 8:08 AM
DAVE H
  • 13,384 POSTS
CLUTCH PEDAL FREE PLAY
NOTE:Clutches are a single, dry disc type. Adjustment for wear is not possible. Clutch is actuated through hydraulic master cylinder and slave cylinder, and is self-adjusting.
Hydraulic system should not require addition of fluid under normal circumstances. Reservoir fluid level will increase as normal clutch wear occurs. Avoid overfilling or removing fluid from reservoir. This will cause clutch release problems.
Jan 28, 2009 at 10:03 AM
