2000 Dodge Dakota Cab smells like engine compartment
2000 DODGE DAKOTA
147,000 MILES • V8 • 2WD • AUTOMATIC
MBOULANT
When driving, the cab smells strongly. I'm not sure how to describe the smell other than it smells like burnt fuel/oil. It's always there. When I start up, I get a burst of the smell.
To give some background; I just replaced the intake manifold gasket, spark plugs, all fluids, PCV valve, air filter. I only replaced the intake manifold gasket because I was told by someone who's judgment I trust that it may be causing the smell. I have not done anything with the exhaust to try to remedy the problem. I just can't seem to figure out why it smells so strongly inside the cab. I'm pretty knowledgeable when it comes to cars, but I'm no pro. Any help would be greatly appreciated.
Thanks,
Mike
Dec 16, 2009 at 3:40 PM
CH112063
  • 1,320 POSTS
Can't see any oil leaks?
Dec 16, 2009 at 3:44 PM
MBOULANT
There are no oil leaks, but there is a leak in the transmission hose right behind the radiator.
Dec 16, 2009 at 3:48 PM
CH112063
  • 1,320 POSTS
Sometimes especially in gear(these cooler lines have pressure only in any gear except Park, the air from moving will allow the oil to spray onto the exhaust, and transmission oil is like motor oil, a 20 or 30 weight but different cleaning and better hydraulic properties. Maybe this could be what is happening. Try having a helper put the truck in Drive or nuetral, and watch the oil, to see if its leaking. Only at drive or higher speeds, Spraying back slightly or even enough for the smell. Please use the parking brake, ok. The reason you aren't noticing this is because of the fact you may be checking it in Park, and it doesn't have the pressure. These lines should be replaced. There are part numbers right on them and they come in pairs. Just an idea, I just want to help. OK That may be it. In 99, I was doing one trans after another. Many from leaking lines, unnoticed at idle. Check this sir, ok?
A small leak, will cause a 3000 dollar failure, or a smell at first. A great truck. Good luck.
Dec 17, 2009 at 12:00 PM
MBOULANT
Thanks for the advice. I just noticed the transmission lines the other day and that is my next project. I rarely drive the truck, for various reasons, but I'm in the process of getting it running. The smell is the last thing on my list to address. Thanks again for the help. I'll reply back once I replace the lines and let you know the result.
Mike
Dec 17, 2009 at 1:38 PM
CH112063
  • 1,320 POSTS
Ok, I'm glad its not too bad a leak at this time. If you keep an eye on it vit should be ok for a short time. The catalytic converter was an rotten egg smell sometimes. Good luck.
Dec 18, 2009 at 1:43 PM
