ABS and brake light come on after you turn on the car?
14,700 MILES • 6 CYL • 2WD • AUTOMATIC
JOE77
the ABS and brake light come on after you turn on the car. I set the emergency brake and released it the light went away for about 10 min. and came back on.
Jan 11, 2008 at 1:39 AM
SQM
  • 6,383 POSTS
Anytime the ABS or brake light gets illuminated, it signals an issue within those systems.
Best course of action would be to get the ABS codes scanned. This can indicate what might be the issue. It could simple as a sensor that is loose or defective or issue with the ABS module.
Here is a guide on how to check the codes:
https://youtu.be/rTtAnsOlZU4
You might find this ABS repair guide helpful:
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Sep 16, 2021 at 5:46 AM
