2000 dodge dakota 4 cyl stick
CEK
  • 20 POSTS
Engine Performance problem
2000 Dodge Dakota 4 cyl Two Wheel Drive Manual 100k miles
good power to coil good fuel pressure, installed new coil still no spark no trouble codes 0443
Jan 10, 2009 at 6:41 AM
MOBILEOILANDMORE
  • 39 POSTS
How are you checking the power at the coil.
Jan 10, 2009 at 4:45 PM
CEK
  • 20 POSTS
power to coil on both sides while cranking still no spark replaced coil , cranked ok still no spark??? help
Jan 11, 2009 at 2:12 AM
CEK
  • 20 POSTS
https://images.2carpros.com/forum/automotive_pictures/298656_july_4th_2008_061_1.jpg
Jan 11, 2009 at 2:47 AM
CEK
  • 20 POSTS
power to coil, new coil, powerpulse to injector,s have not cheked pickup coil in dist not sure test process,or crank sensor location
Jan 11, 2009 at 11:11 AM
CEK
  • 20 POSTS
[quote:013cd29aa3="cek"]power to coil, new coil, powerpulse to injector,s have not cheked pickup coil in dist not sure test process,or crank sensor location[/quote:013cd29aa3]checked it with my dvom also test light
Jan 12, 2009 at 1:39 AM
CEK
  • 20 POSTS
[quote:2f26d6fbe9="cek"][quote:2f26d6fbe9="cek"]power to coil, new coil, powerpulse to injector,s have not cheked pickup coil in dist not sure test process,or crank sensor location[/quote:2f26d6fbe9]checked it with my dvom also test light[/quote:2f26d6fbe9]
Jan 12, 2009 at 10:35 AM
MOBILEOILANDMORE
  • 39 POSTS
sounds like the pickup coil you should have a pulse at the coil.
Jan 12, 2009 at 1:24 PM
