1999 Dodge Dakota Vibration
106,000 MILES • 6 CYL • 4WD • AUTOMATIC
TOMGREIG
My steering wheel vibrates when my truck goes into a new gear at about 25 mph. The vibration continues until about 33 mph when everything goes back to normal. The transmission was been rebuilt 9 months ago and the transmission sensor was replaced about 2 weeks ago. Ball joints and tires replaced about 12,000 miles ago. Any idea what the shake is all about?
Mar 14, 2010 at 7:11 AM
  • 110,248 POSTS
If you only feel it in the steering, then it is related to the front end. Do you only feel it when it shifts?
Mar 14, 2010 at 4:40 PM
TOMGREIG
[quote:b7681e757b="tomgreig"]Shakes or Wobbles problem
1999 Dodge Dakota 6 cyl Four Wheel Drive Automatic 106000 miles
My steering wheel vibrates when my truck goes into a new gear at about 25 mph. The vibration continues until about 33 mph when everything goes back to normal. The transmission was been rebuilt 9 months ago and the transmission sensor was replaced about 2 weeks ago. Ball joints and tires replaced about 12,000 miles ago. Any idea what the shake is all about?[/quote:b7681e757b]
Yes, the problem only appears when when the truck shifts into that particular gear. This happens every time it is in that gear and the vibration in the steering wheel is worse if I am applying light pressure on the gas peddle. As the speed increases, the vibration subsides and finally goes away.
Mar 15, 2010 at 1:11 AM
  • 110,248 POSTS
Check for a broken motor mount.
Mar 15, 2010 at 1:19 AM
TOMGREIG
[quote:bc8f1e9a0e="Jacobandnickolas"]Check for a broken motor mount.[/quote:bc8f1e9a0e]
Thank you. I will do that. I do not drive the truck hard. What would cause the mount to break?
Mar 15, 2010 at 1:31 AM
  • 110,248 POSTS
They can just get old and the rubber bushings go bad. Check that and let me know what you find.
Mar 15, 2010 at 3:10 AM
TOMGREIG
[quote:502a72da4a="Jacobandnickolas"]They can just get old and the rubber bushings go bad. Check that and let me know what you find.[/quote:502a72da4a]
Thanks, I'll get back to you.
Mar 15, 2010 at 3:15 AM
  • 110,248 POSTS
You are welcome and thanks for using 2carpros.com.
Mar 15, 2010 at 3:52 PM
