1999 Dodge Dakota two time to start engine, and steering lo
180,000 MILES • V8 • 4WD • AUTOMATIC
JONNYLAW
  • 5 POSTS
I have a few miles on this truck, but it seems it take two or more times to get it started. The engine turns over fine, nor is there engine noise, also low on power from take off,. I have also tried to locate a intake leak but have yet to find one..
Also I have a steering problem, the steering wheel has a lot of play in it, turn a few degrees on the steering wheel and then it catchs up to the turn, I have also looked at the pitman arm and front wheel bearings but they all seem tight....
any help would be great
Dec 12, 2009 at 9:19 AM
  • 110,248 POSTS
As far as the steering, check the tie rods (both inner and outer). Keep in mind, with 180K there could be some play in the rack.
Now for the starting, I have to ask questions. First, If the engine is running and you shut it, does it start right back up? Also, have you ever had the fuel pressure tested? Has the check engine light come on? And finally, have you ever checked to make sure the catylatic converter is plugging. THat could cause both a power loss and hard start.
Dec 12, 2009 at 5:06 PM
JONNYLAW
  • 5 POSTS
No check engine light at any time, also when I turn the key off , yes it starts right up with no problem. For the converter I haven't had it checked , is there a way I can do that my self or I need to take it in.
This truck has great heat , burns no oil. I drive it slow any way seeing its not a race truck I just want to get the turdiness out of it . If that makes any sense.
Dec 13, 2009 at 1:53 AM
  • 110,248 POSTS
Make sure there is good pressure from the exhaust. Also, with the engine running, listen for sounds near the converter that may make indicate it is plugged up. Finally, drive the truck at night and let it get hot. When it starts loosing power, pull over and look at the converter. If it is cherry red hot, it's plugged.
Let me know what you find and thanks for using 2carpros.com.
Dec 16, 2009 at 1:12 PM
JONNYLAW
  • 5 POSTS
The power loss and fuel usage is getting worse. The convertor is ok, and I have the new Mitchell on demand car repair cd's and have done the re-routing for the plug wires for the spark knock on accelerating. ( still has spark knock) I have also checked for vaccum from the pcv valve just in case the plentum gasket was going bad but that checks out ok as well .. No check engine lights at all, no codes either. And to answer there is no fuel coming from the tail pipe either, no oil loss,
Just trying to see if this is a simple hard to find repair or should I pay big money for a dealer with the right computer to check it out for me . Seems I have done every thing i can my self so far,But this truck takes off like a 4 cylinder and uses gas like a fleet of cars.
Any other help would be great
Dec 25, 2009 at 2:21 PM
  • 110,248 POSTS
I didn't know you had spark knock. This changes things. First, a bad EGR valve can cause this. Remove it to make sure it isn't plugged with carbon as well as where it bolts to the intake. Also, make sure the valve is functioning.
Next, spark knock many times is caused by a bad knock sensor. The sensor's job is to advance the timing to the max point right to where the ping/knock starts then retards the timing to prevent the knock. You may want to check that too as well as check you ignition timing. It could be too far advanced causing the noise and power loss.
Check that out and let me know what you find.
Dec 26, 2009 at 4:57 PM
JONNYLAW
  • 5 POSTS
After investigating this 5.2 v-8 doesn't have the EGR set up nor the spark knock sensor.
Is there any thing else you can think of to try nest,, thanks
Dec 27, 2009 at 11:25 AM
  • 110,248 POSTS
Check the ignition timing to make sure it isn't too advanved. Let me know what you find.
Dec 27, 2009 at 5:12 PM
JONNYLAW
  • 5 POSTS
I had the local dodge dealer reflash my pcm also no change in the spark knock, and finally see that i'm getting about 9 to 10 mpg, how is that and why is that, the dealer ship here states its normal( i dont see how), any further help, its already cost me 125 just to reflash and no fix, runs fine, good idle, just dont know, also can a faulty fuel pump cause this ,, also seems theres more power whens its really cold out side... thanks
Jan 10, 2010 at 3:20 PM
