1999 Dodge Dakota timing
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
CRZAJOE
Timing chain went, put new one on put it to tdc check to see if the valves were bent check the shut down relay,It is getting spark, It sometimes pops throw the throlle body smell fuel sorry gas I omed out the cam sensor, It won't get spark if the crank sensor is bad I don"t know please call 845 386- 3704 or e-mail me www.crazjo22@yahoo.com
Nov 3, 2008 at 2:00 AM
  • 110,251 POSTS
Hi:
If it's poping throught the intake or exhaust and won't start, the timing is out. Check out the "Popular Cite Links" on this page, and go to "Timing Belt MArks." put in your vehicle's information and it will bring up a drawing of how you should have set the timing. Make sure it's correct.
If you have any other questions, let me know. However, based on your description, it sounds out of time.
Nov 3, 2008 at 2:34 AM
