1998 Dodge Dakota TIMING CHECK
1998 DODGE DAKOTA
169,000 MILES • V8 • 4WD • MANUAL
RILARSON
Ive got 1998 dakota w/5.2L what would be the correct way to check the timing. I have spark knock and rough idle. Could this be a result of timing jump or worn timing chain. Thanks for your time
Nov 13, 2008 at 1:35 PM
  • 110,244 POSTS
Hi:
It could be timing or just cheap fuel. If you try better fuel, does it go away? Also, you may want to check the knock sensor. If it's bad, it will cause the same problem. It could also be caused by a crank or cam sensor. You may want to stop a a nationally recognized parts store and have them scan the computer for trouble codes. If there is a code stored, it will identify what the problem is. Most stores will do it for free.
If you want to check the timing, you will need a timing light. The proper timing will be on the truck's idntification info inder the hood.
Let me know what you find.
Nov 14, 2008 at 3:59 PM
