1999 Dodge Dakota Spare Tire
1999 DODGE DAKOTA
BROBUSH
Tires and Wheels problem
1999 Dodge Dakota V8 Two Wheel Drive Automatic
The spare has not been removed in about 3yrs. Now I have to get it off, but the cable system that holds it in place won't work (broken?). How can I get the spare off without damaging the aluminum rim?
Dec 14, 2008 at 5:19 AM
  • 110,240 POSTS
Hi:
I recommend spraying the cable and gear assembly with WD40 or the =. Allow it to sit over night, tap on everything lightly with a hammer and see if it works. If it doesn't, you'll have to cut the cable.
Let me know how it goes.
Dec 15, 2008 at 10:09 AM
BROBUSH
Thanks Joe, but the tire is in the way. I can't even see any of the assembly. I think I'll have to cut the bracket that holds the tire up.
Dec 16, 2008 at 4:02 AM
  • 110,240 POSTS
Hi:
Are you able to get anything under the tire / wheel and pry? There has to be a way.
Dec 16, 2008 at 6:38 AM
