1999 Dodge Dakota replaced trans and now cant get to start
62,000 MILES • 6 CYL • 2WD • AUTOMATIC
NJPWEP74
i had my trans rebuilt and have not been able to get the truck to start.i replaced the coil and still no spark?HELP
Mar 17, 2010 at 1:44 AM
  • 110,246 POSTS
IS the crank sensor on the bell housing installed?
Mar 17, 2010 at 3:22 AM
NJPWEP74
[quote:0b9f336481="Jacobandnickolas"]IS the crank sensor on the bell housing installed?[/quote:0b9f336481]
just installed new $120 crank sensor.turned engin over 2 times and cracked sensor in two. what could have done this????
Mar 17, 2010 at 1:17 PM
  • 110,246 POSTS
It sounds like it wasn't properly installed. It had to hit something. Check for evidence of where / what may have hit it.
Mar 18, 2010 at 1:13 AM
NJPWEP74
thats what i was asking you !!!!!!!!
Mar 18, 2010 at 1:59 AM
CARADIODOC
  • 34,407 POSTS
Depending on the manufacturer of the sensor, there will either be a thin plastic rib on the end that is designed to wear off or you must install a paper spacer on the end which will slide off when the engine starts. Those are designed to set the proper air gap. If you're installing a used sensor that had a rib, it must be sliced off, then the paper spacer must be used. If the new sensor didn't come with the spacer already stuck to the end, they are available from the dealership parts department.
caradiodoc
Mar 18, 2010 at 3:53 AM
  • 110,246 POSTS
He is correct. They must have an air gap. If you don't it will be hit and break.
Mar 18, 2010 at 6:22 AM
