1999 Dodge Dakota rear window
1999 DODGE DAKOTA
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
FRANKF
i have a leak in rear window,how do i remove to reseal it
Mar 23, 2010 at 1:38 AM
  • 110,244 POSTS
You'll need silicone spray and a guitar string or nylon string that is thin and strong. First, open the rubber flap that is on both the outside and inside and spray it with silicone. Force the string through a corner. Work the string back and forth while you carefully place pressure on the rubber weather stripping pushing outward. Do this until enough is apart to remove the glass.
Reverse the process to replace it.
Mar 25, 2010 at 2:14 PM
