1999 Dodge Dakota no pressure in the engine cooling system
AMYTRINKAUS
Engine Cooling problem
1999 Dodge Dakota V8 Four Wheel Drive Manual
I have had trouble with my 99 dakota overheating. I have replaced several parts to fix the problem, I have also flushed the system many time and still have the problem. Now I found I have no pressure in the cooling system. What do I need to do to fix this problem?
Aug 24, 2009 at 5:21 AM
  • 75,988 POSTS
Check the water pump and radiator cap
Aug 24, 2009 at 8:09 AM
AMYTRINKAUS
We have replaced the water pump,Fan Clutch and the radiator cap. Yet I still have the problem of NO Pressure. I kneed to know what to check for this problem. Thank You
Aug 25, 2009 at 8:15 AM
  • 75,988 POSTS
Pressurize the cooling system-did you replace the thermostat. No pressure in the system entails to major leak somewhere-
Aug 25, 2009 at 9:07 AM
