1999 Dodge Dakota no pressure in the engine cooling system
AMYTRINKAUS
  • 1999 DODGE DAKOTA
Engine Cooling problem
1999 Dodge Dakota V8 Four Wheel Drive Manual
I have had trouble with my 99 dakota overheating. I have replaced several parts to fix the problem, I have also flushed the system many time and still have the problem. Now I found I have no pressure in the cooling system. What do I need to do to fix this problem?
Monday, August 24th, 2009 AT 12:21 PM
Check the water pump and radiator cap
Monday, August 24th, 2009 AT 3:09 PM
AMYTRINKAUS
We have replaced the water pump, Fan Clutch and the radiator cap. Yet I still have the problem of NO Pressure. I kneed to know what to check for this problem. Thank You
Tuesday, August 25th, 2009 AT 3:15 PM
Pressurize the cooling system-did you replace the thermostat. No pressure in the system entails to major leak somewhere-
Tuesday, August 25th, 2009 AT 4:07 PM
Related Air Conditioner Not Working Content
