1999 Dodge Dakota No four wheel drive
60,000 MILES • V8 • 4WD • AUTOMATIC
KDMOW01
Recently (Nov 09) when I tried to use the four wheel drive on my truck it would not work. The last time I used 4x4 was probably February 2009. The 4x4 worked last winter but this time it did not work. I have a small gear shift 2wh/4wh/N/4wL down near the gas pedal over the drive train. I am not sure if when I shift the gear it is a purely mechanical shift into 4x4 or if it is electronic. Based on the location of the shifter I am thinking that it is mechanical. Can you help me get my 4x4 back?
Nov 14, 2009 at 6:46 AM
CH112063
  • 1,320 POSTS
I think it is mechanical but uses vacuum to move a shift fork.
Nov 14, 2009 at 12:45 PM
