1999 Dodge Dakota Fuel injection
1999 DODGE DAKOTA
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
BOOTSS
#5 cyl. not firing.Pull injector wire,no rpm change.
Compression good,spark & spark plug good,plug wire & cap good.
Replaced #5 injector,checked each injector wire(both sides for voltage & Pulse) all seems normal yet cylinder dosen't fire??
Thanks Ahead
Sep 2, 2009 at 9:13 AM
RACEFAN966
  • 5,029 POSTS
If you would pull the number 5 wire and ohm it and let me know what the ohms are the length of the wire. Also what brand of plugs are you using? Have you replaced the plug to see if you have a bad one? Get back to me thanks.
Sep 3, 2009 at 4:03 AM
BOOTSS
wire reads 4000ohm about 16" long.Found cracked porcelin on spark plug.All plugs gapped at .080?
rest to .040,Champion plugs.Problem solved,thanks.
Sep 4, 2009 at 12:07 AM
RACEFAN966
  • 5,029 POSTS
Great glad to hear it. It runs like it should again. So the plug gap didn't understand what you said about that but as long as you gapped the plugs to the specs on the sticker under the hood then no worries. Thanks for you support and if you have any other questions please just ask.
Sep 4, 2009 at 2:56 AM
