1999 Dodge Dakota Driveshaft removal problem
1999 DODGE DAKOTA
145,000 MILES • 6 CYL • 4WD • MANUAL
TIMMESSINA
  • 10 POSTS
I am trying to remove the driveshaft to replace the clutch but when i unbolt it the shaft does not slide back into the yoke i was wondering if there is an easy way to unfreeze the driveshaft without using torches?
Apr 18, 2009 at 6:13 PM
BMRFIXIT
  • 19,053 POSTS
I would think using torches would melt the seal and possible other internals
it should slide push in and then pull put
Apr 19, 2009 at 7:05 AM
