1999 Dodge Dakota DRIVE BELT
JAMES RUSCH
Engine Mechanical problem
1999 Dodge Dakota Two Wheel Drive Automatic
HOW DO I RELIEF THE LOAD ON THE SPRING TENSION PULLEY TO REMOVE THE BELT. ALSO IS THE THREAD WHERE THE FAN SCREWS ON TO THE WATER PUMP RIGHT OR LEFT THREAD
tHANKS JIM
Oct 3, 2008 at 1:24 AM
  • 110,248 POSTS
Hi:
To remove the tension from the belt tensioner, you will need a ratchet or a box end. The tensioner will have a slot for a ratchet or you will place the box end over the tensioner pulley bolt. Then just push or pull the tensioner in the direction to loosten the belt.
The fan screws are a standard right handed thread.
Oct 3, 2008 at 2:05 AM
