1999 Dodge Dakota Brake Fluid
216,000 MILES • V8 • 4WD • AUTOMATIC
SGROVER
Why am I not getting any fluid to the rear brakes? I have replaced the lines, master cylinder, and both rear drums, shoes and adjusters. I have tried bleeding with no success.
Oct 10, 2010 at 12:59 PM
  • 75,988 POSTS
W/ Four Wheel Antilock Brakes
ABS system bleeding requires conventional bleeding methods plus use of the DRB scan tool. The procedure involves performing a base brake bleeding, followed by use of the scan tool to cycle and bleed the HCU pump and solenoids. A second base brake bleeding procedure is then required to remove any air remaining in the system.
Perform base brake bleeding.
Connect scan tool to the Data Link Connector.
Select ANTILOCK BRAKES, followed by MISCELLANEOUS, then BLEED BRAKES. Follow the instructions displayed. When scan tool displays TEST COMPLETE, disconnect scan tool and proceed.
Perform base brake bleeding a second time.
Top off master cylinder fluid level and verify proper brake operation before moving vehicle
W/ Rear Wheel Antilock Brakes
Use Mopar brake fluid, or an equivalent quality fluid meeting SAE J1703-F and DOT 3 standards only. Use fresh, clean fluid from a sealed container at all times.
Do not pump the brake pedal at any time while bleeding. Air in the system will be compressed into small bubbles that are distributed throughout the hydraulic system. This will make additional bleeding operations necessary.
Do not allow the master cylinder to run out of fluid during bleed operations. An empty cylinder will allow additional air to be drawn into the system. Check the cylinder fluid level frequently and add fluid as needed.
Bleed only one brake component at a time in the following sequence:
Master Cylinder
Combination Valve
Rear Antilock Valve
Left Rear Wheel
Right Rear Wheel
Right Front Wheel
Left Front Wheel
MANUAL BLEEDING
Remove reservoir filler caps and fill reservoir.
If calipers, or wheel cylinders were overhauled, open all caliper and wheel cylinder bleed screws. Then close each bleed screw as fluid starts to drip from it. Top off master cylinder reservoir once more before proceeding.
Bleed Hose Setup
Attach one end of bleed hose to bleed screw and insert opposite end in glass container partially filled with brake fluid. Be sure end of bleed hose is immersed in fluid.
Open up bleeder, then have a helper press down the brake pedal. Once the pedal is down close the bleeder. Repeat bleeding until fluid stream is clear and free of bubbles. Then move to the next wheel.
PRESSURE BLEEDING
Follow the manufacturers instructions carefully when using pressure equipment. Do not exceed the tank manufacturers pressure recommendations. Generally, a tank pressure of 15-20 psi is sufficient for bleeding.
Fill the bleeder tank with recommended fluid and purge air from the tank lines before bleeding.
Do not pressure bleed without a proper master cylinder adapter. The wrong adapter can lead to leakage, or drawing air back into the system. Use the adapter provided with the equipment or Adapter 6921.
Oct 10, 2010 at 2:09 PM
JARED GUILFORD
Is this recommended for a 1998 Dakota two-wheel drive? I thought you had to start with the right rear left rear front passenger and then driver side front when bleeding?
Sep 7, 2022 at 10:00 AM
  • 110,248 POSTS
The sequence should be right rear, left rear, right front, left front. Always start at the wheel furthest away from the master cylinder.
Sep 7, 2022 at 11:58 AM
JARED GUILFORD
Okay, that's what I thought. I'm still not getting any fluid to the rear drums. I jacked the rear end up and had someone hold the brakes and the wheels spun still. What could that be?
Sep 7, 2022 at 8:48 PM
  • 110,248 POSTS
Have you confirmed the master cylinder is good? If you remove the supply line for the rear brakes and press the brakes (with a rag and a finger over the port) can you hold the fluid from coming out?
Sep 8, 2022 at 11:22 AM
