1999 Dodge Dakota air filter
86,000 MILES • 6 CYL • 2WD • AUTOMATIC
TURFSTER82
How do I remove the air filter housing. I have removing the mounting bolt on the outside. but the inside screw or bolt just turns and it has a different look to it.
Nov 15, 2008 at 4:01 AM
  • 110,248 POSTS
Hi:
Look under the housing and you'll see a nut turning when you try to remove the bolt. You will need to hold that so it doesn't turn.
Nov 18, 2008 at 3:21 PM
