i was wondering if loose shocks in the rear of the truck can be causing the truck to shake it's lifted and i changed all of the ball joints upper and lower got it alighned and changed all 4 tires and got them balanced. i also got the drive shaft checked and it was fine and i changed the front axel. i was wondeing if the rear shocks can be the cause of the shake because when i shake the shocks the shake alot so can that cause the truck to shake.
Oct 28, 2010 at 5:56 AM
