1999 Dodge Dakota
TLAMPP19
Transmission problem
1999 Dodge Dakota V8 Four Wheel Drive Automatic
how do you get to the torque converter bolts to remove the transmission and also do you have to remove the transfer case
Oct 1, 2010 at 5:38 AM
  • 110,248 POSTS
The transfer case needs to come off first. As far as the torque converter, there is an inspection plate between the trans and engine. Remove it to access the bolts.
Oct 1, 2010 at 4:42 PM
