1999 Dodge Dakota
MORGANBILLY66
Air Conditioning problem
1999 Dodge Dakota V8 Two Wheel Drive
how do you change ac compresser clutch
May 25, 2009 at 10:38 AM
  • 110,251 POSTS
Disconnect Battery.
To remove the compressor, you must evacuate the freon in the system. It requires a specific tool to do it. Any other way is against the law. After it is removed, then just remove the belt, unbolt the compressor from its mounts, and disconnect the wireing. Reverse order to replace.
May 26, 2009 at 3:13 AM
