1999 Dodge Dakota
DENTAL
  • 1999 DODGE DAKOTA
Electrical problem
1999 Dodge Dakota 6 cyl Two Wheel Drive Manual
I tried to start my truck and lost all power. Nothing works
Friday, August 21st, 2009 AT 8:34 PM
JDL
  • 16,098 POSTS
Hello, if your saying the starter won't even crank? I'd make sure the battery has a full charge and the battery connections are good. Then, I would check the circuits at the starter relay. The voltage for load side of relay is hot all the time. Voltage for the coil side of relay, goes hot with the key in the crank position.
Saturday, August 22nd, 2009 AT 11:23 AM
