1998 Dodge Dakota water driping inside cab on passenger sid
29,000 MILES • V8 • 4WD • AUTOMATIC
BENNY VENTURINO
condenation is driping out the air conditioner drain tupe and also inside the cab close to and under the glove box area on the floor. I would like to fix this my self , I'm being told there is propable some debris blocking the condenation to drain all out the tube. Is this some thing simple to fix my self. thanks . benny
Nov 6, 2010 at 12:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes you can just slide something stiff and small into the drain tube, do not stick it very far in though and go slowly otherwise you risk puncturing evaporator .
Nov 6, 2010 at 12:55 PM
BENNY VENTURINO
This did not fix my problem, had to take car to dealer,cost me 125.00 . found small pin hole in plastic under dash on pasenger side. they put some exposy glue on the hole . told me not to use heater or air for a couple a days. Don't no if this fixed the problem. tube was clear. Benny
Nov 9, 2010 at 9:29 AM
