1998 Dodge Dakota Truck will not Idle
POKERCHRIS26
  • 1998 DODGE DAKOTA
  • 6 CYL
  • 140,000 MILES
Truck will start, run for a second, and then die. If I start the truck and pedal the gas I can keep it running. What could it be. Fuel filter, pressure regulator, or a sensor?
2/27/08
I have not been able to perform tests yet due to work schedule. But today after work I came home and was going to start diagnosing the problem. The truck started right up with no problems. It had a smooth idle and there were no warnings lights. ? I started and stopped the truck multiple times with no problem. What could get better by just sitting in the drive way?
Monday, February 25th, 2008 AT 6:53 PM
Test the engine coolant temperature and throttle position sensor and idle air control valve/motor. If all checked out-perform a fuel pressure check and comeback with your findings.
Monday, February 25th, 2008 AT 7:09 PM
