1998 Dodge Dakota Transmission leak
1998 DODGE DAKOTA
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
BLASEP
I have a bad leak from the rear of the transmission, where it bolts to the transfer case. Is there a rear seal that can be changed if I remove the transfer case?
Thanks[img:9dcce797ea]http://www.2carpros.com/forum/automotive_pictures/203392_IMG_05251_1.jpg[/img:9dcce797ea]
[img:9dcce797ea]http://www.2carpros.com/forum/automotive_pictures/203392_IMG_05151_1.jpg[/img:9dcce797ea]
Feb 10, 2010 at 9:50 AM
  • 110,240 POSTS
Chances are the tail seal is leaking. Yes you need to remove the transfer case to access it.
Feb 10, 2010 at 10:23 AM
