HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Dakota
Engine Cooling
Water Pump
Replace/Remove
1998 Dodge Dakota replacing water pump
BIGBEAR
MEMBER
1998 DODGE DAKOTA
6 CYL
2WD
AUTOMATIC
123,000 MILES
How do you take the clutch fan oo
Monday, October 20th, 2008 AT 7:28 AM
MECHANIC
Hi:
There should be 4 bolts holding it on to the pulley. At first they be hard to see, but look hard and you'll find them. Most likely, you'll need an open ended or box wrench.
Tuesday, October 21st, 2008 AT 11:28 AM
Please
login
or
register
to post a reply.
Related Water Pump Replace/Remove Content
1998 Dodge Dakota Cooling
I Replaced The Thermostat, The Water Pump And The Radiator. The Engine Itself Is Not Overheating But I Am Getting Alot Of Steam And Mist...
Asked by
brudan
1998
DODGE DAKOTA
VIDEO
Water Pump Replacement
Instructional repair video
1998 Dodge Dakota Water Pump Noise
I Replaced The Water Pump A Yr Ago, And It Seems That When It Is Moist Either Rain Or Snow Damp Weather There Seems To Be A Squeeling Noise...
Asked by
donc
1 ANSWER
2 IMAGES
1998
DODGE DAKOTA
I Cant Afford To Take This In To A Repair Shop I...
My Dodge Dakota Temp Runs 210 Arround 40mph And Raises To260 At 70 Mph And Cools Back Down When Returning Back To 40 Mph. If I Turn The...
Asked by
mudtug
1 ANSWER
1998
DODGE DAKOTA
1995 Dodge Dakota How Do I Remove The Water Pump
I Need Info On Replacing A Water Pump.
Asked by
nlhomer
1 ANSWER
1995
DODGE DAKOTA
2001 Dodge Dakota Changing Out Water Pump. How To...
2001 Dodge Dakota 6 Cyl Automatic 90,000 Miles Cannot Remove Old Pump. Please Instruct. Also, I Do Not Know Wheel Drive Type. My...
Asked by
Sue Gatlin
2001
DODGE DAKOTA
VIEW MORE
Heater Hose Replacement Chevrolet Camaro
Cooling System Pressure Test
