1998 Dodge Dakota Re: part name
100,098 MILES • V8 • 4WD • AUTOMATIC
SRFNDOLL
i cannot find a diagram to correctly identify the part on my dakota that is broken.
The plastic part that holds the fuel filler neck in place to the body of the vehicle is cracked. The fuel tank neck now has no downward pressure to be able to fill the tank. This cracked as i was inserting the nozzle from the pump to the fuel tank neck.
Thank you for your prompt answers.
[img:faad6ad999]http://www.2carpros.com/forum/automotive_pictures/305223_fuel_tank_part_1.jpg[/img:faad6ad999]
Jan 20, 2009 at 9:46 AM
MERLIN2021
  • 17,250 POSTS
I dont know either, but the junk yards are full of good ones, figure out what tool you need to remove it, then go get it at the junk yard. Let's try calling it the filler neck skirt, or apron...
Jan 20, 2009 at 9:58 AM
SRFNDOLL
Thank you for the lead...It gives me a place to start. I spent all afternoon trying to find it in a diagram.
Thanks,
Sfrndoll (with a wrench in her hand cause her daddy taught her to be independent.)
Jan 20, 2009 at 10:57 AM
MERLIN2021
  • 17,250 POSTS
No problem.
Jan 22, 2009 at 10:49 PM
