1998 Dodge Dakota Radiator Flushed in September / Squeaking
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
GRAYSON
I had the radiator flushed in September and right away there was a high pitched squeaking when I start the engine in the morning. Some days it's louder than others.
What could be causing this? I never had any squeaking until the radiator was flushed.
Nov 26, 2009 at 10:23 AM
CH112063
  • 1,320 POSTS
It may be that some chemicals spilled on the belts. That is all I can think of, the belts are sensitive to any coolant and can lose their glaze. Then they squeal, especially on a start up, as the alternator is replenishing the amps lost in starting the engine. They sell a spray anti-squeal lubricant you can spray on the belts, one may be a slight bit loose or old. The water pump, I'm sure is ok.
Nov 27, 2009 at 6:30 AM
