1998 Dodge Dakota no spark
GARY SWANSON
Engine Mechanical problem
1998 Dodge Dakota 6 cyl Two Wheel Drive Automatic
Engine turns over, replaced coil. no spark..could it be pickup coil or module?
Jun 23, 2010 at 10:38 PM
BMRFIXIT
  • 19,053 POSTS
Suspect crank sensor
turn key on you should have a check engine light on
crank engine light should go out if not suspect crank sensor and or its wiring
scan for codes ,
Jun 23, 2010 at 11:14 PM
