1998 Dodge Dakota no spark
GARY SWANSON
  • 1998 DODGE DAKOTA
Engine Mechanical problem
1998 Dodge Dakota 6 cyl Two Wheel Drive Automatic
Engine turns over, replaced coil. No spark. Could it be pickup coil or module?
Thursday, June 24th, 2010 AT 5:38 AM
BMRFIXIT
  • 19,053 POSTS
Suspect crank sensor
turn key on you should have a check engine light on
crank engine light should go out if not suspect crank sensor and or its wiring
scan for codes.
Thursday, June 24th, 2010 AT 6:14 AM
