1998 Dodge Dakota Heater is barely warm
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
DYNAMO1887
When running my dakota and needing to use the heat if I have the heat cranked all the way hot I barely get any warm (at best) air. My engine thermostat also says that my truck is running around 160 degrees. What would be the best solution for these issues
Jan 28, 2009 at 11:56 PM
  • 110,248 POSTS
The engine should be running around 195 degrees. Replace the thermostat and it should take car of the problem.
Let me know if you have questions.
Jan 29, 2009 at 2:35 AM
