HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Dakota
Climate Control
Heater
Heater Core
SPONSORED LINKS
1998 Dodge Dakota heater core
T CAP
MEMBER
1998 DODGE DAKOTA
Heater problem
1998 Dodge Dakota 6 cyl Automatic 225000 miles
My father in law has to replace the heater core, can you tell me the easiest way to do it?
Thursday, February 28th, 2008 AT 5:53 PM
BMRFIXIT
MECHANIC
Sorry no short cut or easy way about it
every thing has to come out
instrument panel and all
if not sure may I suggest a manual also u can find it @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
good luck
SPONSORED LINKS
Thursday, February 28th, 2008 AT 9:33 PM
Please
login
or
register
to post a reply.
Related Heater Heater Core Content
98 Dodge Dakota Sport - Heater Core?
V6 Model. Odo Is Just Shy Of 100k. We're Planning A Party. When I Crank The Heat For The Morning Commute, I'll Get Heat For A Little...
Asked by
kingfisher
1998
DODGE DAKOTA
GUIDE
Heater Core Replacement
A heater core is positioned inside the car and is part of the HVAC system. Hot engine coolant is run through the core which air is blown through via the blower motor which ...
1998 Dodge Dakota Heater Core
I Lost Heat While Driving This Morning, The Check Gauges Light Came On And The Temp Was High. I Turned Off The Heater And Fan And The Temp...
Asked by
bpakulski
1998
DODGE DAKOTA
1998 Dodge Dakota Leaking Heater Core
This Past Winter I Started To Smell Anit Freeze In The Cab Of My Pickup. I Checked Under The Hood And Didnt Find Any Leaks. I Also Checked...
Asked by
chuckcam123
1 ANSWER
1998
DODGE DAKOTA
Dodge Dakota Heat
I Have A 1998 Dodge Dakota Sport V6 3.9l. I Have Been Having Problems With My Heater And All I Get Is Warm And Cold Air From It. I Recently...
Asked by
jaybrydge
1998
DODGE DAKOTA
Does The Heater Box Definitely Have To Come All The Way Out Of The Truck Or Can I Take The Top Off The Heater Box After Everything Is...
Asked by
wigtail
9 IMAGES
2000
DODGE DAKOTA
VIEW MORE
SPONSORED LINKS
Heater Hose Replacement Chevrolet Camaro
Coolant Leak Symptoms
Online car repair manuals
