1998 Dodge Dakota Headlights
DASK
  • 1998 DODGE DAKOTA
  • 6 CYL
  • 184,000 MILES
Lights sometimes flicker off then on again when you turn them on or go to high beam, they will stay on if on low beam while driving but still sometimes flicker when you first turn them on but not all the time. I was told it was the dimmer switch so I had a mechcanic put a brand new one in but the lights are still doing the same thing once in awhile, could this have something to do with off and on switch or the bulbs them self. Looking for answers.
Thursday, November 13th, 2008 AT 8:28 AM
  • 110,182 POSTS
Hi:
Based on what you said, it sounds like the problem is in the high beam switch. Before replacing that, have a mechanic check it for you. Also, make sure the lights' electrical plugs are tight and clean.
Saturday, November 15th, 2008 AT 12:03 AM
