1998 Dodge Dakota grinding noise
120,000 MILES • 6 CYL • 2WD • MANUAL
TOM ELBRECHT
hello when i turn right and apply throttle a grinding noise accurs it started years ago now its geting bad i have changed all wheel bearings and universal joints i had rear end open and it wasnt full of metal filings i can use any helpican get thankyou very much its driving me crazy tom
Jan 3, 2009 at 4:00 AM
  • 110,248 POSTS
Hi:
can you identify where the noise is coming from? Have you had the CV joints checked? Does it only happen when you turn?
Jan 3, 2009 at 8:53 AM
TOM ELBRECHT
noise is coming from rear end this is two wheel drive only when i turn right is there any rear end specialist there ty tom
Jan 11, 2009 at 1:20 AM
  • 110,248 POSTS
The only thing I can think of is the rear differential needs shimed. This seems to be a common problem with their differentials. When shimmed, the problem should be fixed.
Jan 11, 2009 at 2:48 AM
TOM ELBRECHT
ok thank you verymuch tom
Jan 11, 2009 at 7:52 AM
