1998 Dodge Dakota Fuel Pump?
1998 DODGE DAKOTA
85,000 MILES • V8 • 2WD • AUTOMATIC
JWBOSCH
For about a month about the same time I liowered my truck, at a slow start the truck would dye. Start it back up and all's fine. This might happed 1 in every 10 -20 starts. Now my wife just called and the truck will not idle she has to keep pumping the gas to keep it running. Im quessing it to be the fuel pump. Just how difficalt is it to test and replace if needed?
Thanks Jeff.
Aug 2, 2008 at 6:23 AM
BMRFIXIT
  • 19,053 POSTS
( liowered )-----> ??
check idle valve clean and or replace
check for vacuum leaks
Aug 2, 2008 at 12:20 PM
