1998 Dodge Dakota Brake light will not go off
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
JRMATTOS
  • 15 POSTS
Sometimes when I get out of my truck my brake light stays on. I have to keep stepping on and pulling up the pedal for it to go off. Do you have any suggestions
May 6, 2009 at 11:20 AM
  • 75,988 POSTS
Adjust the brake switch
May 6, 2009 at 1:16 PM
JRMATTOS
  • 15 POSTS
That didnt do the trick... sorry
Jun 17, 2010 at 7:32 AM
  • 75,988 POSTS
If you disconnect the switch and the lite is still On-the wire when it leaves the brake switch is shorted to a power source somewhere within the electrical system which is hot at all times could be the wires on the brake connector is shorted together
Jun 17, 2010 at 7:37 AM
JRMATTOS
  • 15 POSTS
You dont think it could be the speed sensor?
Jun 17, 2010 at 7:50 AM
  • 75,988 POSTS
It has nothing to do with the VSS-
What did you do with the brakes switch earlier-replace it ????
Jun 17, 2010 at 7:56 AM
